Injectors! which ones?
LaserRed5.0
Ok so soon I will hopefully be running a supercharger. The only parts left for me to buy are injectors. I've been basically looking for a new set and everybody told me to look at the 42 lb injectors, however they don't make the actual Bosch ones anymore for whatever reason. So then I was looking at 39lbs which wont work due to the cobra head/injector spray pattern ordeal. Now what does everyone think about the 47lb injectors from ford racing I know they'll need adapters, but they are fairly cheap. Or accell 44lb injectors? Anyone know of a good brand/sizing or what to go for and stay away from? Any suggestions are appreciated. Thanks.
SMOKEDYA
Tucson Az.
What all is done to your car? Is it a 5.0,5.8.4.6? I assume its a 5.0 since its a 95. If your a 5.0 42"s will be enough. If your running a 351 I would go with the 60's at least. If it's a 4.6,im really not positive but I bet 42's will work as well? If your running over to the wheels you will want a different MAF or better yet use a slot style out of an 05+. The lightning MAF to match the 42's max out at close to 450. I believe the 42#'s came in the newer lightning's? Here is a few links from fleabay. They and a matching MAF are usually readily available on there and also svtperformance.com.
http://www.ebay.com/itm/8-42-lb-For...Parts_Accessories&hash=item1c39453f85&vxp=mtr
http://www.ebay.com/itm/96-98-Cobra...Parts_Accessories&hash=item485d2d9170&vxp=mtr
stillridin
