Installed my Paxton now trying to fix the bugs
GThang98
I have base tune in the car right now and the car is running rich as hell , well my question was is okay to use my stock maf with the blower or should I upgrade to a lightning maf and if I go with the maf would I need extra to make it work
blown98gt
no you wont need anything extra to make it work if you have a 4.6 if you have a 5.0 then you might need an adapter. (not exactly sure)
I had a Lightning MAF and it was plug in play. You need to get rid of the stock MAF get a Lightning and then get a dyno tune. Real time tune by a tuner can't be beat by some mail order tune :)
read more here for MAF information.
http://sn95forums.com/index.php/topic,37141.0.html
Paxtons setups are draw-thru MAF's
if you've got 42 lb injectors then you should look at this.
http://cgi.ebay.com/ebaymotors/Ford-Racing-Lightning-90mm-Mass-Air-Meter-MAF-Brand-New_W0QQcmdZViewItemQQcategoryZ42604QQihZ013QQitemZ230339256737QQrdZ1QQsspagenameZWDVW"]Link 1[/url]
If you have a 5.0 (best deal so far)
http://cgi.ebay.com/ebaymotors/90mm-Lightning-Mass-Airflow-Sensor-MAF-harness-filter_W0QQcmdZViewItemQQcategoryZ33557QQihZ002QQitemZ120422107031QQrdZ1QQsspagenameZWDVW"]Link 2[/url]
G
GThang98
I'm going to order one this week so I can get my car tuned! What sparks plugs should
Run cause Paxton recommends the autolite 764s , how much power you guys tthink I'll make, I got stage 1 cams, Paxton blower running 8 psi and Anderson power pipe with shorty headers, lightning maf, x pipe, slp catback, 75mm tb and
Plenum and pi intake
blown98gt
if paxton knows all your supporting mods and recommends autolite 764 then use them..
blown98gt
call autolite and ask them, they can tell you exactly what to gap your plugs at
Green Goblin
if it's only 8 psi you can use the stock maf. you could try some ngk tr6 gap in the 30 range. that's going to add a little over a 100hp to the flywheel and then subtract you 10-15% drivetrain loss for rear wheel hp. get new 02's also help it run a lot better.
