Intake Plenum
Orange Stang
Is an intake plenum woth it? how much extra power we talking like 2rwhp? I have a JLT intake and a 70mm t/b so am i losing out by not having one. I really never found one I like. i was thinking of getting a c&L and just sanding it and polishing it out....
mtang98 gt
i have stack racing plenum on mine. I think with a tune it helps in the higher rpms when the car is starving for more air. But if you wana go the less exspensive route i cant see how polishing and sanding out wouldnt help. As long as you can see a difference between the stock and aftermarket there should be improvement.
duff daddy
Thats what im using. Last year I had the Trickflow upper plenum. The best conventional upper plenum and throttle body is the Accufab its the choice of guys who need every last hp
97stanger
I used to have an accufab plenum on my old setup, but now use a 6061 race plenum
bredman
yo duff what do you think about the bbk upper plenum thats what im thinking about runing
LI98GT
Long Island, NY
Blown,
Sweet looking plenum.
As far as hp improvements go, yeah just a couple of hp. I went with the TF for the price and quality since the other standard ones were tested/rated very similiar and a good friend supplied a 70mm tb to go along with it. So it looks better than stock and adds a few hp with only a little work and coin.
reference and pics.....
http://www.modulardepot.com/articlesp.php?aid=38
TF plenum pics:
If you can find a used one cheap then I would go that route. They do add a few hp and the difference between the best and worst is minimal. From most of the tests I remember reading the Dragon was the highest gain in hp but not by much.
duff daddy
I dont like bbk stuff really. I only ran their h pipe on my car last year. If I had to chose and it wasnt an elbow like I have now, it would be the Accufab t/b plenum combo.
chaz
Draper UT
My Stock Plemum is ported and polished to match my TB, it allows the motor to breath at 6k+ RPMs and still looks stock (sleeper look), I feel it will be perfect with my hidden Nitrous set up and built auto setup.
duff daddy
What cams are you running? and do you have ported heads?
chaz
Draper UT
I am just running PI Cams and Stock Pi heads right now.
duff daddy
then dont run teh car to 6k. The motor becomes innefficent well before the 6k+ range. I shifted ported heads and comp 270's at 6100.
chaz
Draper UT
I think my shift points are at 5900 RPM's, even though my dyno sheet shows that I should shift at 5700 my auto likes shifting at 5900+ to get me down the track fastest.
Blk97GT
I have my shift light set to 5.6k, so by the time I actually shift its about 5.8k, seems to work good for me. This is on a bolt on PI motor.
Haha don't let Adam from the Misfits see you say you love Accufab. When he had his 2V he used to rip them all the time on here and make long writups on how they are over priced and how he lost ET compared to a FRPP TB and ported stock plenum.
