Intake swap HELP?
Foster98GT
I had my PI Intake installed the other day, a local shop did it. Now My car skips. I checked everything i could think of, spark plug wires, cables & hoses everything. It has a light skip. I can step on the throttle about a quarter of the way anything after that i get hesitation....What could it be? :TY:
96gt226410
You said you've checked plug wires, but have you pulled the plugs? They may have spilled coolant on them.
F
Foster98GT
Very Possible! I was gonna have a look but decided to take it back to them. They got my money, they need to get it RIGHT!
yes, pull the plugs. check them good. i had a fouled out plug after i installed mine. make sure you have your wires on good when u reinstall them. chack and be positive there is no coolant down in the holes.
i had the EXACT same problem you are having.
Willis_98GT
DFW Texas
i had the exact same problem when i swapped my manifold.. check your last plug boot that is on the passenger side.. mine had a inch of coolant in it.
and if a shop did it. then they should get you a new set of plugs and install to cover their asses i think. :knuppel2:
reivaxtorres
also make sure the plug wires are on right. i had 2 of mine mixed up and you could tell it had a misfire when driving around.
Goldmember
Cornwall, NY
When we did my intake we pulled all the plugs and turned it over to clear the cylinders out.
One of my dad's coworkers has a '97 Town Car, he and his buddy swapped intakes but didn't pull the plugs. Bent a rod. Had to tear it down. D'oh!
