is it true???
akaslick15
i have been told from a couple friends of mine that i can run E85 gas on my stock sn95 no mods to engine except a 2 and half exhaust setup with some flows now if its true i just wanna get the facts right cause im going with a turbo setup in the future and i know alot of guys that do it with there turbo setup cause it runs cooler.i mean does anybody thinks its safe to run E85 on a 5.0 h/o motor
blackhorse
Brazil
You need a 30-40% larger injectors , a 255lb/h fuel pump (dual with turbo or SC) and a tune .
With N/A H/C/I or stock engine you will need a 30 or 42lb/h injectors , and turbo or SC engine you will need a 70lb/h (BSFC-0.84 , 600hp , 15% safety margin w/ 39psi fuel pressure) or 90lb/h injectors (BSFC-0.84 , 750hp , 15% safety margin w/ 39psi fuel pressure) .
blackhorse
Brazil
No . Fwhp .
Until 500fwhp : 42lb/h injectors (N/A) . Until 350fwhp : 30lb/h injectors (N/A) .
Until 600fwhp : 60lb/h injectors (boosteed) . Until 750whp : 90lb/h (boosted) .
That with 15% injector safety margin ,0.60 BSFC for N/A application and 0.84 BSFC for turbo/SC engine , 39 PSI fuel pressure , 242lb/h fuel pump for N/A until 350fwhp , 345lb/h fuel pump for N/A until 500fwhp , 580lb/h fuel pump(s) for boosted until 600fwhp and 725lb/h fuel pump(s) for boosted until 750fwhp . Fuel pump safety margin of 15% . Note : All nominal injector flow rates are quoted at a delta pressure of 39.15 psi .
EDIT: For boosted application , one 255 lph fuel pump is good for 500 fwhp with 64lb/h injectors . You can use 60lb/h injectors and bump fuel pressure to 45 psi . Fuel pump safety margin of 15%. Two 255 lph pumps with 80lb/h injectors feed 700fwhp . Fuel pump safety margin of 37% .
Just for reference : I'm running E100 for a year and a half now with 255lb/h walbro pump without any problems. So , the walbro is handle great on pure ethanol until now. Last year I opened the engine to change cam and the intake manifold and pistons were shining from inside , ehehehehe . And no smell of crappy gasoline . You can just finished the job and go out with your girl with the same clothes without any smell of fuel ...
