just bought a new cam
hottwheels04
I have a f303 cam, just so you kno this cam is a blower cam I regret using it on my n/a 306ci,I could be making my 306 a 400hp 306ci I have more left on the table if i went with a n/a cam or custom, this cam is good for top end thats about it, I have 3.73 gears, and its power band is from 3,000-6,000rpms, vs stock is 1,000-5,200, and other n/a cams are more low end 1,500-2,000 rpms up to 5,500, your gonna want 3.90-4.10 gears if u go with this cam n/a,I miss all my low end power now, the only benefit with this cam is, after 4,000 rpms top end is strong, vs other cams fall on there face top end. :BangHead:
hottwheels04
95blackstang said:
i plan on going turbo but not untill i buy new heads, intake, injectors and maf
k good, its good for a power adder, but if u go n/a 3.90 or 4.10 gears, 2nd gear rolll @ 3,000 rpms this car would rip new assholes with the fcam, im thinking if i stay n/a to up my gears.
I know you hate to hear it but you should wait to install the cam for when you do the heads and intake also. The cam by itself will probably make your car slower.
thesource
<----- not a fan of F cams at all . Good luck getting the factory efi to work with it unless you get it tuned .
