Just Installed BBK O/R H Pipe!!!!
New 5.0
i just finished installing bbk o/r h on my stock 95gt. very happy with sound and the way car is running, but it fills like i am missing something ("yeah i know i missing a lot of goodies")...lol but on the serious note i fill like i may be missing something along the lines of maybe a Fuel pressure regulator, tune, cold air intake, something. car has very lite stumbles after install
I would appreciate any ideas
Thanks
N
New 5.0
I know, i also just replaced the o2's. Its not a big deal its just feels like it may be lacking some fuel or somthing.
Win
Kennesaw, Ga
You should be fine if your worried about it start by giving the car a Tune up. You say Fuel ok then change the Fuel Filter then.
N
New 5.0
I cleaned the MAF,put new plugs,wires,rotor/cap,coil,and O2 sensors. am i missing anything involving a tune up?
N
New 5.0
(ttocs)
I haven't done the intake part yet. what you say makes sense.
(FaykSaleen)
I have messed with the timing, but I cant really remember what it was set to . I do know it wasn't much at all. Would you have any suggestions?
toyman
Base timing is 10*. Mine stock ran fine at 14* on 87 octane. If yours pings at 14* either back it off 1* or switch to a higher octane.
N
New 5.0
Not the problem I am having. I Just in stalled a o/r h and all is good just fells like it may be missing something. i have read somewhere that they recommend a fuel regulator when you make this change. Does anyone know if that's true?
Lee12609
You need to explain your problem. Saying you're missing something means nothing.
Fuel pressure regulator isn't going to help without dyno time.
I've never heard that one before.
I swap back and forth between my o/r h and catted h with no changes to my stock system and no ill effects either.
I do get better fuel milage without the cats though.
N
New 5.0
I got the answer i was looking for. But thanks anyways. As far as the fuel regulator, i was just stating something i read.
toyman
There is nothing about installing an O/R H pipe that is going to cause a hesitation. If it occurred it is merely coincidental.
N
New 5.0
FaykSaleen said:
Has your timing ever been messed with?
i messed with the timing long before the install and never had this problem. to be honest it feels like i may be running a lean?? what were you suggestions when you asked your question?
