Kenne Bell intercooled?
modo
Philadelphia, PA
Blakonblak94 said:
Also would it be possible to trigger meth of a WOT trigger setup?
Yes but that is not ideal. It is best to have a progressive controller so the water / methanol is added and ramped up linear with load / rpm of the motor.
modo
Philadelphia, PA
Blakonblak94 said:
Ok that makes sense. How expensive is it to run that stuff?
~500 for the kit. you can buy the pre-mixed stuff for about 5 bucks a gallon or just use -20 degree windshield washer fluid which is < 2 bucks. I buy 99.9% meth from a chemical place for 25 bucks for 5 gallons then mix my own.
teal94gt
i had a problem with heat soak on air charge temp relocated it to the upper intake made a world of difference 347 kb 2.2 with the flowzilla intake 9lbs of boost 385.5 rwhp and 491.7 rwtq fun to drive on the street
Blakonblak94
Blakonblak94
The torque is nice, but with 9lbsof boost with a centri on a 347 the hp numbers would be a good bit higher, am I right?
teal94gt
have freind running the centri setup on 347 putting higher hp numbers but with the torque mine makes can walk off from his car every time
BLOWN 95GT
Alabama
Blakonblak94 said:
What turbo kit did you end up going with? Also would it be possible to trigger meth of a WOT trigger setup?
Pony downs hotside parts and home made intake pipeing, and snow performance makes a stage 2 and stage 3 boost cooler kit that has a controler to adjust when and how much methanol is injected per lb. of boost. I had a stage 2 kit and it worked well but the stage 3 kit is a lot better. You can usually find pretty good deals on them on ebay thats where I got mine and I only payed $150.00
Blakonblak94 said:
How far will that go?
Depends on how much you put your foot in the gas pedal!
LAFENATU
Definitely.
Blakonblak94
Blakonblak94
I suppose it depends on if you wanna embarass folks off the line or walk em later.
BLOWN 95GT
Alabama
Blakonblak94 said:
Haha let's say normal driving how far will a tank go?
Normal driving it would last forever, it only sprays when your in boost. I bought 4 gallons of premix from snow performance went to the Dyno made 3 pulls, and went to a couple of car shows maybe 2-3 hundred miles of driving racing crotch rockets and some friends cars and I still had over 3-1/2 gallons left. It is still sitting in my garage because I sold the supercharger kit and methanol kit but couldn't ship the methanol with it.
Blakonblak94
Blakonblak94
That stuff sounds like it's on my wish list. Anything I need to purchase meth, or can I get it pretty easily.
BLOWN 95GT
Alabama
http://www.snowperformance.net/product.php?pk=3
This stuff is already mixed for you so you don't have to do anything but pour it in and go. And you don't have to get any special license or anything to buy it just a debit or credit card.
Blakonblak94
Blakonblak94
Excellent. I greatly appreciate the help. Im gonna start saving. Hoping that by next spring I'll have enough in the bank. Hard for a 19yr old college student to save money ha
BLOWN 95GT
Alabama
Don't worry I feel your pain, Im 26 and my back pocket stays empty between my house payment, wife, and 2 year old It gets hard to save anything.
