Leaking caliper
ElrodKTPQ_89
Crossett, AR
Finished up my front suspension swap today and installed my cobra brakes. When the time came to bleed the brakes, as soon as I started pumping the pedal both front calipers were spewing fluid from underneath the banjo bolt. So we took both hoses off and cleaned the surfaces of the hose/caliper and the copper washers and reinstalled them. Second time around the passenger side held up but the driver was still leaking, so we called it quits for the night. On the driver caliper, when we removed the bolt the first time a little bit of thread came out with it, but when we reinstalled it it still snugged up tight and did not feel to have been stripped out anymore. Is it possible that the caliper is screwed up or maybe I'm just not getting a good seal around the surfaces between the caliper and washer, and washer and brake hose?
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
I commented in your build thread. Anyway, did you install new washers when you swapped them out? They are kind one-time use. I don't ever reuse those once they get broken loose.
ElrodKTPQ_89
ElrodKTPQ_89
Crossett, AR
I did not, we reused the original washers. First time I've ever worked on the brakes so I didn't know better. Buuut I went ahead and ordered some stainless hoses from MM, so that should remedy my problem I hope.
lwarrior1016
South Mississippi
That should fix you up nicely! :thumbsup:
Burninriverdiver
Sounds like you've got it figured out! Those copper crush washers are no good twice, once they've been smashed down they don't do their job at completing the seal the second time around. Just throw some new ones on and get them nice and snug
ElrodKTPQ_89
ElrodKTPQ_89
Crossett, AR
I hope this is it. After all the time and effort spent on cleaning and painting the brakes I'd hate to have to get a new caliper and strip and repaint it. Plus I'm ready to drive my freakin car home lol
Cwacaser
