long tubes
CompOrangeSN95
North Jersey
I'm looking to get a set of long tubes with 3" collectors, i found a set from summit for 100 bucks anyone know if they will fit a 94?
The part number is SUM-G9030
Also if you have any ideas where to get a fair priced set let me know. Thanks
Gtnut1996
i got a set from a friend of mine about 3 months ago that we believe are the exact same headers. they do not have a logo on them to tell for sure. they will not fit a sn95 because they hit the starter. we were told they would work so i had sand blasted them, sprayed them, bought collectors and gaskets, and took the exhaust off just to find out they would not work. i actually am selling them to a guy with a fox because i know they will work on it.
Gtnut1996
didnt see how. they would not bolt to the heads because it hit it. they are slip tube long tubes also. my buddy didnt have any leaking problems though.
F1atlander
Kennesaw, GA
i tryd em too. only way i could've made them fit was to crush the tubes enough that it would have been more restrictive than the orginal headers
P51CrazyHorse
Summit DOES sell a Longtube header for the '94/'95 Mustangs. They're BBK brand, and I have two part numbers you can look at. First is standard, second is ceramic coated.
BBK-1519 $295.95
BBK-15190 $409.95
Hope this helps.
blackpony
i dont see how they would hit the header... A 302 from a fox and sn95 are identical.... Dosnt matter what u take it out of a 302 is a 302... I am currently running a set of fox lt's on my 95.... Only difference is there isnt a provision for the egr tube... Other then that, they are identical....
LAFENATU
because the locations are different on the SN95 to fit the engine bay.
blackpony
LAFENATU said:
he said that they are hitting the starter....
also there is no difference in the fox headers and the sn95 except the egr provision... a buddy of mine has a set of lts just like mine on his 94 cobra and the only difference is he has a provision where i dont... mine are for a fox.....
there is a ton of threads just like this one.... use the search button
Jerry santos
