I am looking at a Mishimoto Fan. They say that it is a big upgrade.
http://www.brothersperformance.com/p-23-97-04-ford-mustang-46-fan-shroud-kit.aspx
i hope your car downt have abs. if so kiss it goodbye!!
at those speeds the car shouldn't be getting hot. Airflow through the radiator should be enough to keep it cool. If it is in fact getting hot at interstate speeds something else is wrong besides the fan. Do you have an aftermarket temp gauge so you can actually tell how hot its getting?I have a brand new radiator and hoses. My issue only presents itself when the outdoor temperature is 90 degrees+ and I am driving over 60-65 mph. Because of the 3:73 gears, I run at about 2500 RPM while at 65-75 mph. Thats when the temp creeps up.
Tonight when I get to work, I'm going to fabricate something to divert more air up to the radiator. The bottom of the radiator frame has a metal frame with holes in it and it's angled at 45 degrees. I'm going to use that to attach something that extends downward to catch the air and divert it up into the radiator and see how well that works.
I have the stock temp gauge. Like I said, when its 89 degrees or so i have no issues. Its when the temps are in the 90's-100's and I'm driving around 70mph it gets warm. Thats about 2400 RPM with the tune and 3.73 gears. The needle will go slightly past half way(Dead center middle)- A little to the right of center of the letter "M". I'm guessing 195 degrees maybe. I would love for it to be dead center all the time like it usually is.at those speeds the car shouldn't be getting hot. Airflow through the radiator should be enough to keep it cool. If it is in fact getting hot at interstate speeds something else is wrong besides the fan. Do you have an aftermarket temp gauge so you can actually tell how hot its getting?
There is no reason runnin 70 at 2500 rpm would mean that you do not have enough air over the radiator. Do you think the fan pulls the air through at by itself at 70? it is nowhere near that speed. I would say your problems with heat have more to do with the underdrive pullies then the fan. They slow down the water pump in order to gain the 3-4 hp that they give you. Also makes it much harder on your alternator since it is designed to rotate and cool itself at a certain speed. Slowing it down generates more heat as well as make your headlights dim at lights, even if you didn't replace the alt pulley, had to replace yours yet? I had UDP's long enough to realize that they were not gaining me enough performance to justify the problems they cause. Before you drop more money into a fan, why not swap those out and see if you notice the difference in performance or the difference in temps.
set you engine back. get lots of room.I need more clearance. my fan works fine but I am wanting a little more room between the turbo and the fan.
