Do this, except, i would run the sender wire to the computer harness. It gets messy with wiring to the O2 sensor harness. With the O2 harness under the car, you have 2 options: red wire w/ black stripe is driver side
grey wire w/ light blue stripe is passenger side.
On the computer harness, as i remember its a red wire towards the front of the car on the outside portion. Ill look tonight if you wanna give me a call.
thanks man, I have a wdeband that has its own stuff and works seperatly. I am installing this low band to fill a hole for now also, plus the leds going back and forth looks cool I think. The Wideband I like better. I'll give you a shout tonight If I don't figure out which computer in exactly.
Autometer's website has guidance on what pin on the ECU you can tap into for narrowband O2. However, the gauge itself is pretty much worthless anyway - except it's a neat light show. This is especially true if you already have a wideband.
Thanks paul. I found the info I needed on the site, Try to find those wires tommorow. really pointless guage when you have wideband already, but I figure it looks cool.
