low coolant light sensor ???
xs man 27
I have a low coolant light on in my instrument gauge cluster.. I was wondering if anyone has a link to a site that sells them cheap ??? thank you
X
xs man 27
where is the sensor located also ? sorry dumb newb questions....
Suspect
ATL
Its in the overflow bottle.. throw some fluid in it. It will shut off, but u might be loosing some somewhere.
uncltrvlnmatt
Pa.
Don't just look at the bottle and see green and think it is full. The plastic overflow bottles will stain over time and if you don't physically look, it may look full when it is empty.
chris91
Cincinnati, OH
Or you could just have the typical dead sensor inside the tank. If you normally keep your eye on your fluid levels you can just unplug that sensor and the light will go off.
Pete@FTR
Preferred Vendor
Rocklin, CA
That idiot light is a waste of time, just pull the sensor and your light will go out :thumbsup:
DeepList
Administrator
Auburn, IN
I doubt the sensor is bad. If the light is on, than your coolant level is probably low.
When I put the aftermarket coolant expansion tank on the cobra, there wasn't a place to put the sensor, so I just left it disconnected. The light remains off when the sensor is disconnected.
Lawrenceburg Kentucky
Good tech guys...thanks. The coolant light in my ride stays illuminated, so I'm figuring a cleaning of krusties is in order.
X
xs man 27
thanks to all who replied ,, I just did everything mentioned from pouring a lil more anti freeze in, clean the sensor and the three prongs,.. no more light... easy fix... thanks again everyone
Srchop16
