mach 1 tweeters
94SN95
Hey guys I want to install some mach1 tweeters I just bought is there a bracket or something to hold the tweeters in place?
Ohh I forgot this is going in a 94 GT I do not have a mach 1 stereo.
Matt94GT
Im assuming its just like the Mach 460 tweeter pod? You remove your inner plastic corners where your mirror are. My Pods had one hole in the back for a screw then I retrofitted someafter market tweeters in place, I thought the tweeters just slid tight in the pods, if not there is obviously some sort of bracket needed. What I did to get mine to fit tight was wrap a layer of Foam tape around the tweeter, then it fit nice and tight in the tweeter pod hole, put the cover on and no one would know, worked great.
94SN95
Hey Matt I want to install the mach 1 tweeter it is not an after market tweeter I just need to know if there is some type of bracket to mount it with??
Matt94GT
Like I said im not positive, probably though... a metal bracket to hold it in the tweeter pod. But im sure if you do what I did it will work just fine. Wrap some foam tape around the tweeter, stuff it in the tweeter pod hole, put on the, or just make a simple bracket out of some of that metal you can get at hardware stores to make shelf brackets with.
joekd
Ct
The mach and non-mach door panels are different, just looked at zgadson's how to and he shows sawing off the bases of the pods
JiMi_DRiX
Tucson, AZ
What? Why all this modifying about clips and stuff? I didnt even quite understand it..
I understand why you cut the base of the tweeter housing off, but other than that, it takes one self tapping screw to mount them into their stock location and youre done. I put them in mine, and thats all I had to do.
