MAF on a 95 cobra
pagz
Hello everyone. My cobra is all stock except for removing the air silencer and dropping a k&n filter, 70mm tb, mgw shifter and lowered with strange adjustable shocks/stuts. I have a spare pro-m maf calibrated for 19lb injectors from my 93 gt, and want to know if I can put it in my cobra? From my understanding is that the 94-95 cobras uses a maf calibrated for 19lb injectors and the ecu makes all the adjutsments for it work with it's 24lb injectors. So will there be any problems in installing this maf onto my cobra? Thanks.
Pedro
SvtBlack95
i think the 94-95 cobra mafs are only for 24 lb injectors.... i think there might be a problem there
95 Sleeper
Negative ghostriders....He is correct! the 94-95 (cobra)Mass air meter is calibrated to 19lbs injectors and the computer does do the correcting for the 24's
P
pagz
Thanks for the info....I will just have to try it to see if it works.
Pedro
95 Sleeper
Pedro
10-4 you should be fine
senior001
