mil eliminators
fbms-02gt
how many will i need for my 02 gt for an off raod h pipe and will i pass emissions withthem
thanks for ur help guys im 18 i need to learn the ropes
danielson631
you only need two for the rear sensors(2).
im not 100% sure but i beleive you will pass inspection with them.
i also have an o/r H and i passed inspection with the MIL elims on.
but im not sure if the guy cut me a break on the emissions test. i know he cut me a break on visual inspection lol
someone else will chime in with a fo' sho' answer
Lee12609
you only need 2 to get the light off, but if you have emissions they should fail you regardless based on NOT having the cats to begin with.
Ninety8stang
Duh405
You'll only need the rear 2. The front 2 are for you air/fuel and your rear 2 are for cat efficiency. If you don't have the front 2 sending a signal your car will run like crap if at all.
F
fbms-02gt
ya but if u just hook up the o2 to the fronts and put the mil on the back two i should be all set correct
Lee12609
all set for what?
the check engine light will go out unless you have other problems, but if your state does emissions inspections you will probably fail the visual inspection...
