Trickflow.GT
- Joined
- Nov 23, 2006
- Messages
- 463
- Reaction score
- 0
is the maf cal'd for #36 injectors?...if not take the 36's out and put your stock 24's back in...
Stangbangin said:where did you hear this crap? common sense tells you on a stock motor you run a stock injector. 24 #er's would be too big for him right now. 36#er's are gonna have him running pig rich.Addermk2 said:common theory is that the largest you should run on a stock motor is a 30# injector. Any bigger than that, and the injector just isn't opening enough for the fuel to atomize properly, and you get a rough idle!
cdsmith_2002 said:I called this Pro-M this morning (very helpfull Tech Support by the way). It turns out that I have the wrong part #. There is a different calibration required for the Cobra ECU. The one from Jegs is for a GT ECU. The Cobra MAF is not a stocked item. :crying:
I'll report back when the correct MAF is installed.
You initial post only stated sometihng about a hesitation and nothing about a power adder so yea it makes sense now. But your hesitation was probably being caused by your maf on its way out not for lack of fuel since you don't really have any major mods.cdsmith_2002 said:Stangbangin said:where did you hear this crap? common sense tells you on a stock motor you run a stock injector. 24 #er's would be too big for him right now. 36#er's are gonna have him running pig rich.Addermk2 said:common theory is that the largest you should run on a stock motor is a 30# injector. Any bigger than that, and the injector just isn't opening enough for the fuel to atomize properly, and you get a rough idle!
How can 24 be too large? 24 is the stock Cobra size. The chart from Accel recommends 30# for up to 350HP and the 36# for up to 400HP. I have to admit that I based my purchase off of a couple of books and manufacturer info. I did not spend any time on the Forums. I've only had this car for about 8 months. I'm not a 5.0 veteran, that is for sure!
now go drive it hard so you can break parts and upgrade those too....thats the name of the game.cdsmith_2002 said:Right one. Since I was forced to buy parts, I wanted them to fit the future plan.
