Modified 5.0 cam question
MyFast5.0
Hey all, I have a 95 mustang gt with a ford racing crate motor. As of now It has a ford racing E-cam. I have to get the motor taken out for a few repairs and id like to up the cam size. Id like to know what the absolute biggest cam I could fit in my car is without having to check piston to valve clearance. I have GT-40 Aluminum heads and 1.7 rockers. Any input is helpful. I want the most aggresive cam out there....thanks!
LAFENATU
Why do you want something bigger?
The E Cam is not a bad cam.
You could swap to something else and I would bet you wouldn't notice a power difference.
MyFast5.0
Imnot woried about adding more power. I was that lope, I was to intimidate, my car is fast enough and has enough power it the sound im going for. Any suggestions?
LAFENATU
If you want lope, and are really willing to do the work of swapping a cam then look at the thumpr cams from comp.
They are designed around lope.
Yellow94gt
Which gt40 aluminum heads? X or Y? What size valves? What are your springs rated to? Willing to change the springs? There are a lot of factors here...
Addermk2
checking PTV takes like... 20 minutes once the cam is in the motor... dont puss out... get something big and check PTV
BigTang
Get the survival motorsports SHR6222, its the old 1087 cam.
intake Exh Dur
RR # @ Valve @ Cam @ Valve @ Cam Int Exh
1.6 1087 319 510 334 534 222 232 112
1.6 E303 311 498 311 498 220 220 110
