Mods-95 Cobra
Joker606
Recently bought a 95 cobra, mods in sig. Just wondering what times do you guys think I will pull in 1/4?
Also i'm debating on going either the turbo or supercharger route. I've read till I'm blue in the face lol. Not sure if I want to do H/C/I before a power adder or not yet. I think down the road the plan may be for 450 hp and a great handling package. Maybe a 331 or something, not sure.
I'm thinking of buying a power adder and tossing it on the stock h/c/i for now and running low boost and a good tune. What supporting mods other than the ones in my sig would I need? Fuel mods? Bigger TB/mass air? Thanks guys O0
ga94gt
Just my 02 but just throw a power adder on there as long as the motor is in good shape. You will need MAF,injectors,adj fuel regulator, 225 lph intake pump, and a GOOD tune.
IceMan
I got a 94 Procharged Cobra... it is not running right now, but when it was it made 602 RWHP 592 TQ at 17psi... on a stock bottom end running stock GT40 heads O ringed unported, full exhaust, Stock unported intake, upgraded fuel system A1000 fuel pump, rails, lines, 60lb injectors 90mm mass air, 75mm TB, F cam, and other smaller mods i cant remember now on the "KILL TUNE"... we also did a more of a conservative tune with less timing and a fatter A/F ratio and it did 575hp and 557 TQ...
J
Joker606
Car only has 22k on it, so I'm guessing motor should be in good shape. So what size Mass Air should I go with, I have a 76mm C&L on there now, also what size injectors? Cobras came with 24#? Should I go up to 30? Goal with this car would be about 450hp. Would the 65mm Throttle body be ok on there or would these be things I could upgrade down the line and it would work right now?
So basically bigger injectors, adj fuel regulator, and 255 pump? Of course tune it conservatively until i get a bottom end and h/c/i? Any ballpark and what this car should run with the mods in the sig?
CobraCop95
depending on how long you plan on keeping the car, i would go ahead and do H/C/I then plan on a turbo or blower set-up...unless you're in a hurry and want to make power fast...just my .02
Stangbangin
just throw a supper charger on it with the fuel upgrades. with the stock block it won't take much more than 450 hp to bust the block down the middle. I have a hci car now and if I were to do it over I'd just throw a sc on it and make more power for less and play with it til it breaks. then when you build another motor you can throw the hci on there.
94 DropTop
id say low 14's high 13's from what ive seen run in the past. but the track here sucks so yo never know
