For Sale Moroso Deep Sump Oil Pan - $175 + shipping
Status
Not open for further replies.
Tabres
Bloomington, Il
For sale: Moroso Deep Sump Oil Pan - P/N 20546 You can view all the specifications of the oil pan at the following link: http://www.summitracing.com/parts/mor-20546/overview/make/ford/model/mustang
I purchased this pan brand new from Summit Racing and used it for roughly 3,000 miles. During the course of those miles it picked up one tiny, almost invisible dent on the bottom of the sump that is located on the outer edge, nowhere near the pick-up tube. It has no affect on the performance of the part. I would also suggest to whomever purchases the pan that they replace the gasket on the drain plug as it began to weep. Otherwise, there are zero issues with the pan. The only reason I'm not re-using it is I chose to switch to a road-race oil pan with extra baffling as I plan on tracking my car.
FULL DISCLAIMER: This oil pan came off of my old engine that incurred bearing damage. It had a considerable amount of metal in it. I have cleaned the pan inside and out the best that I could. However, THIS OIL PAN SHOULD ABSOLUTELY BE PUT IN A PARTS WASHER AND CLEANED OUT THOROUGHLY BEFORE USE. This is the buyer's responsibility. I'd rather it be done to their satisfaction than they just trust me that it was done correctly. I take no responsibility if you fail to clean the oil pan properly, put this on your engine and then experience issues.
Price - $175 + shipping
This image belows shows the tiny dent I spoke about. It is located in the upper right hand corner of the sump.
Status
Vmarch
