MOTOR MOUNTS
19mustang95
between the motor and the k-member. ???
you should see the bolt if you look under the K-member
ripper
If your replacing them get good ones. For some reason the 4.6 motor mounts wear out fast.
Mine were shot when i put in new motor and old motor only had 50k on it.
Thomas_W
Capon Bridge, WV
DriverSide:
The motor mount is the thing in the middle of the engine block w/ the nut on it...
Passenger Side:
A
AaRoN
King Post Whore
thanks for all your help guys but i found them. they were pretty easy to find. i just figured i'd try to make it alittle easier. those nuts on the motor mounts are stubborn!
voidfinger
so the mounts wear out fast huh? so i guess my 138k mile car is blistered :) , guess ill get some poly ones when i do the motor swap :)
voidfinger
Thomas_W said:
DriverSide:
Passenger Side:
Ahhh, turbo headers. where you get those from Thomas
jys97cobra
i had 39000 on the car when i bought it , the left side split in half
voidfinger
almost forgot about this tread. I'm gonna need to find some headers like that for a 4v :)
voidfinger
true, fell threw the cracks. I still think with those kinda headers and someone to make some piping ... you could make a turbo set up for super cheap! i saw some powermaster turbo's for like 500 dollars... i want to see a custom fabbed twin set up.
A
AaRoN
King Post Whore
There is a guy on here from Michigan that has a custom TT setup.
I know you could make your own turbo kit for pretty cheap.
voidfinger
:boink:
Markstang73
