Multiple Codes Need Help
97ponygt
Well had to put my Mustang in storage for a year and a half and wasn't able to drive her around, extenuating circumstances didn't allow for it. So I took her out of storage and now she pulls three new codes. I've sprayed carb spray on all my vacuum hoses twice and didn't notice anything. And once at a stop light it died when putting the defrost on. Those three codes and possible fixes I'm come up with are:
P0300 - Random Misfire Detected
  • Spark Plugs
  • Spark Plug Wires
  • Ignition Coil Pack
  • Fuel Filter
P1151 - Lack of HO2S-21 Switch, Sensor Indicates Lean
This is the drivers side upstream O2 correct? Possibly dirty fuel injectors or filter?
P0151 - Oxygen 02 Sensor Circuit Low Voltage (Bank 2, Sensor 1)
Replace O2 drivers side 02 sensor. Probably going to switch them and see if the code follows.
and the one I've always had is P1443.
Any help is greatly appreciated guys. She's a 4.6L 2V with Auto transmission. And she hasn't gotten much worse gas mileage then normal so not sure where to start next. If I'm going to have to start throwing parts at her, what should I start with? I figured I should do plugs, plug wires and a fuel filter anyway since it's about time those things were replaced anyway.
97ponygt
  • Spark Plugs
  • Spark Plug Wires
  • Fuel Filter
Nobody?
RichV
CO
Well your fuel is probably crap, so I'd run out the bad fuel before you go throwing any parts. If the fuel has turned into varnish, probably not in that time, it will clog injectors like nobody's business.
I'm sure someone can recommend a good fuel system cleaner, and swap out the fuel filter at minimum. You may be replacing injectors if they're sticking.
32vNomad
When was the last time the O2's were changed?
2002 GT | 284ci 32v | 3.73's | Bassani Headers | TR3650 AD | Mach 1000
97ponygt
Yeah I emptied the bad fuel out before starting to drive her around and put seafoam in my first tank of gas.
I haven't for the life of the car and have had an off road H pipe for the last 50,000 miles. She has 131,000 on her right now.
32vNomad
Replace them honestly they should be changed every 50k - 60k. Bad O2 sensors cause a lot of drivability issues. Even if they haven't coded lazy ones are just as bad.
Ninety8stang
Duh405
You should always throw a new fuel filter in it if the car has been sitting for a while. Do a basic tune up on the car and see how it goes. My guess is theres gunk in that filter but i would also change the plugs as well. Shouldnt take longer than an hour and a half or so.
