Mustang diet
D3VST8R96GT
Marble Fall, AZ
there used to be a thread with how much weight you can shed from your vehicle piece by piece
Basically how light can i make the mustang ....i will take out everything i can excluding the drivers seat and such ....but all other seats and any other added weight .....
i would like it sub 3k lbs.
Musturd
Easily doable my old car with no back seat and gutted trunk weighed 3050 with me in it
Raffaelli
Weighed mine at the track a few weeks ago, somewhere around ~3,450. Oh yea im 210.
1/2 tank of gas, full interior, 5 speed, nothing in the trunk.
I honestly thought they weighed more. :cool:
D3VST8R96GT
D3VST8R96GT
Marble Fall, AZ
im gonna gut everything ...maybe keep the crapet in it but the center console is coming out all seats except the driver .....radio speakers if i can ....gut trunk spoiler and maybe the hood too hahahahahah
very little gas
so why such a wide rang of wt dif?
justinschmidt1
Yea, they really dont.
My 96 gt with me in it was roughly 3300 lbs, im about 200 lbs as well.
But I also have an alum block and no rear seat/gutted trunk, on 15 inch drag wheels and skinnies.
but still, even without that weight loss, the car wouldnt be much more than 3300-3400 lbs, tops.
94gtho
I think this is the list you are referring to. I saved it awhile back when I saw it.
Drivers seat Leather 48 lbs
Passenger seat Leather38lbs
Rear seat Leather top half 30lbs
Bottom Rear seat 15lbs
Sounds deadening (Remove w/Torch and Scraper) 45-50 Lbs
Door Panels 8Lbs Each
Extra metal out of front bumper (Center) 8Lbs (Kept most of it)
Front Sway Bar w/links 13.5Lbs
20Lbs going to front coild over setup.
20 Lbs going to lighter front seats with manual sliders.
CD Player Head Unit 5 Lbs
Rear End Dog bone 10 lbs
metal plate under steering column 3.5 Lbs
Wind shield washer tank 1.5Lbs Empty/8Lbs Full
Passenger side air bag 9Lbs
Drivers side air bag 3 Lbs
Air bag sensors and module 3Lbs
Hood latch w/cable etc 2-3Lbs
Cruise control (In Fender) w/cable 2-3Lbs
Glove Box 4lbs
Trunk Lining with spare tire cover 14Lbs
Spare tire 25 lbs
Jack and tire iron 8lbs
Smaller battery 10Lbs
Mach 460 Amp Rack 6Lbs
Mach 460 Speakers 2.25 Each
6 disk changer 2Lbs
Rear Seat belts 5 Lbs
Sun Visors with harness 2.5 Lbs
E-Brake Assembly w/cable 7.5 Lbs
Black boxes behind rear tires w/brackets 3Lbs
rille insert and Radiator cover 2 lbs.
Mott bar and bumpstop bracket 9 lbs.
Fog Lights and brackets 6 lbs.
Rear Bumper support brackets 6 lbs
Factory Spoiler 9 Lbs
Strut tower brace 8 lbs
Complete Front Bumper support 17 Lbs
Quad Shocks w/brackets 8Lbs
Rear Sway Bar 8.5Lbs
Convertible K-Member brace 17Lbs
Firewall blanket 15 lbs
Door Bars 8 lbs
Dead pedal 1 lb
Tailpipes 20 lbs
Evap Canister 5 Lbs
EGR and DPee 4 Lbs
Rear Bumper 25 Lbs
Convertible top pump/motor/cylinders 12 lbs
A/C Complete 30 Lbs
ABS Pump Delete 14 Lbs
99-04 Brake Calipers 10 Lbs Vs. 14 Lbs 94-98 style
wiper motor and linkage 6 lbs
Heater core/A/C box/ fan 19 lbs
Bumper suppor mounts w/wind deflectors 5.5 Lbs
Stock A-Arms 30 Lbs, Tubular A-Arms 15 Lbs
hydro-boost and master cylinder assembly 17lbs
Power steering pump 10 Lbs, Delete pulley 1.2 lbs
Power steering lines and Res 5.5 Lbs
lock mechanism,window motor,wiring harness 12 lbs
Gut underside of Trunk, Trunk will weight 20-25Lbs
ABS Delete Manifold 10Lbs
Few Lbs Misc Nuts/Bolts and Removed Metal.
NCMystic
my engine builder has a sick fox he build with a 410, but back to topic in his fox the took the dash out and gutted it from the back side, added a tiny bit of reinforcement and it ended up weighing 2lbs total. a thought. . .
also wonder how much carpet and headliner weigh?
MadStang
Escondido, Ca
when I took mine out of my old car, it weighed a LOT. the headliner is cardboard basically so it's light.
vermilion
maryland
biggest drop of weight i saw was the electric seat rails, removed front bumper styrofoam and bracket to a tubed front bumper support.
