Alright so I have had my car for a couple of months now and haven't had any problems with it really so far. Well last night I took the car to Gateway Raceway to make some passes and on my 3rd pass I was in 4th gear and the car started sputtering then shut off. I had no clue what was going on so me and a buddy pushed it back down into the parking lot and got ahold of someone with a trailer. I noticed that my fuel pump wasn't kicking on so I figured maybe I had tripped the inertia switch but that was still fine. Well as we were setting there I noticed a 20A fuse that was blown under the dash so I swapped it out and voila the pump kicked on and the car fired right up. Well I tried driving it home and about 15 minutes later I see a blue flash under the dash and then the car stalls out again so I pull off the side of the highway. I swapped it out with a 30A this time hoping maybe that would get me homw but as soon as I turned the key forward it blew as well. So I put it on the trailer and took it home. So then earlier today I was looking under the hood and I had found an old amp power wire that came straight off the battery that had come unplugged and was just laying under the hood so I plugged it back in thinking this was the solution to my problem, went and got some more fuses and put the new one back in and as soon as I turned the key it blew out. I'm assuming that I have a short somewhere but I was wondering if maybe anyone else has had this problem and it be an actual component like the CCRM or the ignition that was bad. Any help would be appreciated. Thanks.
The fuse I am talking about it is the number 18 in this diagram the top left which is a 20A fuse that's for the Instrument Cluster, Transmission Control Switch Module, the Constant Control Relay Module, and the ignition system.
