Sn95 matt
- Joined
- Jan 4, 2022
- Messages
- 33
- Reaction score
- 6
so i have discovered a issue with my car once again so I'm starting to think my running cammed issue is due to electrical/distributor problems i was watching a video of a guy diagnosing his car and he disconnected his spout connecter to see if it ran better with his sn95 5.0 so i tried it and mine did run better the first thing i noticed was it still had a little bit of cam to it but it seemed a lot more healthier it was idling at 600 to 700 rpms instead of 800 to 900 rpms the second thing i noticed was my voltage was higher normal my volt gauge would sit between R and M unless i put it into drive it would go to R but with the spout connecter disconnected it was between M and A I didn't put it in drive to see if it dropped but can someone try to explain what might be causing this or try to explain some other things i should try
