I bought some new 185 trick flow heads with 58 cc combustion chambers and a tko 600. I was thinking about buying a DSS 347 with the flat top pistons(around 11.2 to 1 compression) and a Comp cam XE282 cam. I was just wondering if that would be a good combo?
I already have a milodon pan, long tubes, trick flow R (not box), 75 mm TB, 30lb inj, 75mm pro m maf, anderson power pipe, Summit ignition, distributor, msd coil, taylor 409 plug wires. I also have an AEM stand alone with a wide band O2 sensor. also trick flow 1.6 rockers with the heads. 3.55 gears i think thats about it.
Any suggestions would be great...Thanks
