Need some sn95 5.0 help!
94 Sn-95GT
Venom351R said:
94 Sn-95GT said:
Also 347>351. Much lighter rotating assembly. I believe afr 185's are too small. Id go TW. 170 before i go afr 185's. TW FAC 190's get my vote tho
Not exactly. A 347 is the stroke limit of a 302 block, a 351 can be stroked well beyond 400 Cubic Inchs. The power potential of the 351 block far exceeds the max limit of the 302 being the 347
I agree fully. But a 347 vs 351 was brought up. not a 302 based stroker vs 351 based stroker. or a 347 vs a 400+ CI.
That being said. If you go for a 400+ci motor you better get heads to support it.
My next build which is years and years away is going to involve an aftermarket 8.2" block. and going to be around ~370ci give or take. :grin:
L
Lebedin8654
your future build is what i am thinking down the road. I would like to get a really good rotating assembly and head setup than when i split my block form spraying the hell out of it i will go back with a aftermarket block and spray it even more or boost it!
LAFENATU
Lebedin8654 said:
I am not trying to e-race a dyno or anything like that, i am looking for a good H/C/I setup to reach a power level...My S-trim put down 7.80s in the 1/8 with 400rwhp i am wanting to be in that same area all motor thats it! My budget is whatever i dont mind dropping 2 grand on the H/C/I i just want to know a good setup to get me where i want to me on motor, even if i got to drop a thousand to get me to a 347 than do H/C/I!....My goal is high 7s on motor in the 1/8th and 7 flats on the spray!
You can make right around 400HP with a NA 347. That car would have made 400HP with better heads.
94 Sn-95GT
You say real good rotating assembly. Good plan but... What happens when you split the block and the crank gets phucked. or what not?
wytstang
Snakebit said:
wytstang said:
AFR/TW heads, Wolverine 1087 cam, eddy intake. Spray optional.
good luck finding one....
Speed-Pro CS1177R is it's new name, it went from Wolverine 1087, Speed-Pro CS103R, CS1177R
L
Lebedin8654
CS1177R
whats the specs on that thing and where can i find one?
And if the rotating assembly is damaged when i split the block than o well just bad luck i guess, i hope to have the money for a stronger block before i have that kind of a problem but you never know...I am only a weekend sprayer every once and a while maybe a bottle every month or two so it should last a while...a guy around here had a 347 with a cast eagle crank and sprayed a 150 to 175 shot all the time, the car lasted over 2 years as a DD til the crank split!
wytstang
survivalmotorsports.com used to list it, email them and see if they still carry it.
Inspector13
I would not get a Trickflow top end kit unless your building a mild street car (mine puts down 300 rwhp with my bolt-ons and on the stock bottom end) and I plan on going way bigger.
I'd say get either CNC ported Trickflow heads or some AFRs, either a TFS2 cam or a custom ground cam, and either a Trickflow R or a Holley intake manifold and spray it.
My friend runs a 347 with ported Trickflow heads, custom cam (very simular to the TFS2 cam), and a Holley intake and a 100 shot and runs 10.6's in the 1/4 on spray and puts down just over 400 rwhp N/A.
A 347 with ported heads, nice cam, and a good intake WILL put down 400 rwhp.
