needing some help
snwill95
glasgow.ky
hey folks my names will and i drive a 95 boss im having some trouble with my setup tho
i have a 75mm bbk throtle body with a edelbrock performer 2 upper an lower intake i just put tfs 170 heads with the upgraded springs new push rods 6.70 proform 6.5 rockers and i cant seem to get it to run
any help is grately appreciated
white95
Apex Junky
Admin
Prairieville, LA
Was it previously running and then stopped?
Does the engine turn over and does it try to start at all?
snwill95
snwill95
glasgow.ky
It was running before I bent a pushrod then the new heads were ordered I had it running on Saturday but it was popping real bad out of the intake I unplugged the maf an she ran grate until I tried to drive it then it was bogging out bad I don’t know whatever goin on with it
evilcw311
Most Evil Member!
Louisville, KY
Have you double checked the spark plug wire order in the dizzy??? And then have you verified the timing isn’t way out of wack????
snwill95
snwill95
glasgow.ky
ya we checked all the timing marks and made sure to put everything back as for the wires i have it set up with the 302 ho order
evilcw311
Most Evil Member!
Louisville, KY
Dizzy could still be off. Sometimes when stabbing it down in the gear moves and isn’t set right. It’s worth checking to see if your starting the dizzy and true tdc then set it back 10 degrees.
white95
Apex Junky
Admin
Prairieville, LA
Yup. I’d roll the engine until the #1 piston is at TDC (compression stroke) and make sure rotor is pointing at #1 on the distributor.
Werecow
Virginia
I always like to get a sharpie and mark the rotation direction on the dizzy, and I use a piece of masking tape to mark down the firing order. If you're using the Ford plug wires they have the cylinder number on them, but if you ever make your own I like to get a set of heat shrink numbers so you have each one numbered for each cylinder. But that's just my $0.02 worth....
hazel113
