New build in planning and need some help with some questions
1BadSnakeBite
I have decided on my build for my Cobra and it is going to be a 408 stroker done by Fordstrokers.com. I will be running a set of Trick Flow High Ports on this setup with plans for a Kenne Bell Flowzilla. Problem is this supercharger needs a Cobra intake or GT40 and I cant find one for a 5.8 so this leaves me thinking is this the best route. Can anyone direct me to a 5.8 GT40 intake or Cobra intake somewhere online? It will be ported by TMoss as well. Cam will be a custom cam from Jay Allen. Headers will be Kooks. Still deciding on what size injectors and MAF I will need and some other small things.
LAFENATU
How much are you wanting to put out?
You can set a 408 up to make 500hp N/A if you wanted.
There was someone on another board that just did a 408 10:5 with AFR 225's and a spyder intake that makes almost 500.
1BadSnakeBite
Over 500 with a Kenne Bell. I was told, with this combo and everything else I should be around 650 at the wheels.
Jerry santos
