New Clutch Vibration
mustangspartan
MN
Ok guys got a whole new ford racing flywheel king cobra clutch and adjustable clutch cable kit..
Getting vibration in netural with clutch depressed and none
Getting heavy vibration at 1800 and beyond gets worse as i go up
will happen on engine revs not on speed traveling
So far from a ford tech told me to take the tranny off and then start it see if the vibration continues if so then i need to retorque everything down.
Pilot bearing was changed also and throwout bearing.
Ive heard of linkage issues but that is forum talk and shouldnt be a issue that keeps going with the revs.
Also there is a slight wine nothing much but if you have everything silent and trying to listen you can hear it.
Any ideas past what im going to do with taking the tranny back off??
Addermk2
look at the part numbers you have... make sure the new flywheel is the correct imbalance
Addermk2
If I were you, I'd be taking the trans back out and making sure the flywheel isnt loose
mustangspartan
MN
Thats the plan on monday. I torqued it down to spec and in steps but its seeming off still.
Has a little sound when the clutch is out idle also but when u depress the pedal it goes away..
mustangspartan
MN
Ok So new development did everything right fixed it but now im getting a slight vibration during about 1500-3k then it goes away. Shifter you dont feel it but feels like its coming from the engine. Thinking motor mounts, and balancer are next. It does have new trans mount and pilot bearing. This is a rpm vibration. Does this in and out of gear driving or sitting clutch in or out. No matter what it is the same rpm but will not move vibrate the shifter like how the flywheel was off by a few LB of torque.
