Black_Adder
I Just saying hello. Ive had my 95 cobra for about 5 years now, and last year just got around to starting on the engine. It's currently out of the car, I'm installing the 347 stroker kit in it. Got quite a few other things done. Got a full bilstein drag suspension on there, a built 3.73 posi rear end, perfect launch diff strengthening diff cover, flowmaster american thunder exhaust with a bbk h pipe, and that's just the bottom of the car. For the transmission and engine mounts I have black poly mounts, the engine I have the 272 comp cams can, scat 347 stroker kit, trick flow streetburner intake, upper and lower, 70mm throttle body, 30lb injectors, sct tuner chip for all my mods, gt40p heads with Alex springs on them, the gt40p headers. I'm sure I missed some other things. Now for the stuff I still need to get... I'm getting a new water pump, a new oil pump, tko600 transmission, spec stage 3+ clutch kit, new flywheel, new engine bolt kit so I'm sure I have all new strengthened bolts, and again I'm sure there are other things. Now for my rims and tires, I'm running some Shelby rims, on the rears I have 305/35/18 toyo proxes R888 and on the front some 245/40/18 nittos. Glad to be here!!
