newbie question o.O
94OJGT
So im puting different heads on my 94 gt
and... do i need new head gaskets if i do? :hammer:
Would be a good idea, I thought i read somewhere that you could reuse them as long as the cylinder rings and coolant ports were good but I don't know if i trust that, especially after I saw how they came off.
Mr. OAM
I know some people do reuse their head gaskets but I never will. How many times do you want to remove your heads after you put them on? I don't ever want to.
The gasket is made to function at a specific amount of compression. After they are installed and heated and cooled through many cycles they now retain the new condition. This means that when you torque them down again they are not going to compress anywhere near as much as they did the first time. This is counter to how they are designed to function and the likelyhood of a leak is exponentially increased over using a new gasket. It's like installing gaskets that are much harder than new gaskets.
Also weigh the cost of new head gaskets vs. having to drain the coolant down, remove the intake and heads, clean up your cylinders from coolant and oil than may fall into them when you take the heads off, the cost of another intake gasket, bolting everything back on again.....
New gaskets are cheap insurance. Get new ones and sleep well. :thumb:
Steve
94OJGT
thx i got enw gaskets =p hah
i was just wondering cause i wanted my car ready before a little highway action in a couple days
thought i would have to order them and it would take forever to get here, but they had 2 in stock :happydrunks:
