nitrous on a stock '95 timing?
coats04
plan on running a 100-125 shot on a stock '95 gt.
my question is where should i put my timing at?14,10,8 degrees ??????????
im running a wet kit.ive read where you can tune your motor to its best na (14 degrees timing) and spray when you want.but dont you need to turn the timing down when spraying it?
sam92lx
You could be fine 14degress spraying 100-125 but take my opinion...spray 150 and don't look back.
C
coats04
dont 94/95 ecm's pull timing at WOT and slowly add it back in?
i thought i remebered that right from when i had my 94 cobra.
94 DropTop
I would start at 10 and go up from there to be safe. If you really want to be safe start at 8. Just remember check your plugs, after you fuck up you cant go back.
BLOWN 95GT
Alabama
start at 8 degrees get a set of spark plugs one or two steps colder than stock and gap the plugs to 30-34. With a wet kit your injectors should be ok but may want to upgrade to a set of 24lbs. and uppgrade the pump to a 195lph or 255lph. And make sure your fuel solenoid is activating correctly before you spray it or KABOOM!
