No cooling fan
It could be a bad sensor or ccrm has the relay that powers it and some of the circuitry for it and they are known to go bad. Check all the fuses under the hood and dash to be sure
Akurma
Pennsylvania
You can also try and see if the fan kicks on when you have the AC turned on, by default the fan should come on. If not do what TTOCS said
G
G Man
Chesterfield, Va.
Anti lock indicator came on , idle got rough and cooling fan quit , all at the same time. Fan only comes on when computer temperature sensor is in plugged.
abs light on constant means the reservoir is low unless there is another problem. You could try to pull some codes and see if anything shows up.
