no spark
Jerimiah
My 95 gt 5sp, wouldnt start after i left the key on(it would still turn over fine). The battery got a little weak i put a battery charger on it and it fired right up. The other day it wouldnt start again, just turns over no start. i pulled the coil wire off and held close to block it has orange spark. i put the charger on it again and it fired right up. could this be a weak coil, the PO put a msd coil on it?
g36 monkey
Orlando, Fl
[MENTION=10547]CC'S95GT[/MENTION] is pretty knowledgeable when it comes to 5.0 troubleshooting, maybe he can help you out! :)
it could be just a weak battery, a bad alt or a number of things. Take the battery out and get it tested. Wait 3 hrs after the test, and then do it again as I have seen batteries pass after charging that hours later with nothing hooked up loose power.
