Noob question sorry
916_5.0
I was driving tonight and turned on my right hand blinker and it is going hella fast i checked both back and front bulbs and they are both working but going really quick. so i turned on my left and it was still going normal speed. Do our cars blink faster when the bulb is dead or dying?
916_5.0
The blinker will blink erratically if one of those is out? I wasnt aware of that.
01SportChic
South Florida
It could be your multi-function switch if all your lights are working fine. If its the switch and its really going bad, the windshiels wipers may trigger just from moving the turn signal lever up down foward or back without actually engaging the wipers or signals....
Also a good way to find out if its the multi-function switch is to turn the turn signal off and turn it back on, kinda playing with where the lever is positioned...if the blinker goes back to normal, then its the switch.
916_5.0
I will try that the wipers work fine and they werent tweaking out at all and i was able to go from low to high beams it was just wheni would turn on that right hand blinker. I will go investigate.
