NPI Power!
Brian95SVT
Chesapeake, VA
So with h/c/i, p1sc-2, tb&plenum and exhaust you made 413rwhp at only 10psi!?!?
damnn!!
shits lookin good then haha.
thats kinda the same setup i want.
H/C/I, TB&Plenum and Full exhaust with either a vortech or a procharger
but i was gunna get forged pistons, rod and cobra crank just to be able to handle the power.
i should be very well off.
is your intercooled?
do you have a vid of the new setup?
you should make one if you dont
scarface
those are worked Npi heads though...take that in account when you think about your heads.
scarface
I made 385 @ 8psi, without head work... those heads worked great for him :)
Late4Work
I was told that a full PI swap would raise the compression......resulting in the block blowing up when u put a supercharger on it
Ill go with some ported NPI heads instead :rockyou:
quickstang_1994
Cross Anchor, SC
there wasn't that much of a difference between ported npi and ported pi on there site. The difference wouldn't make more than a few horsepower more if any.
Brian95SVT
Chesapeake, VA
so just porting the NPI heads and gettin a new cam and intake plus exhaust and S/C will make 400?
cuz i have PI intake, npi heads, npi cam and full exhaust. if i got another cam and ported my npi heads then S/Ced it, i would be set?
forged bottom end would let me run more psi as well.
ALITL8
its all about how much you want to spend and how fast you want to be ;)
Daywalker
Yep, that's about right. Another thing I just found out yesterday, is that the adapter plates that come with the Livernois kit are port matched to the head, but not so much to the intake itself. There's a local machine shop that's port matching the plates on my buddy's 96 GT, they're expecting good gains from this. I was thinkin about doing it, but I'm already pushing the limits of my shortblock so OK for now...
peasant99
