Oil pan and pick up tube (1996 Mustang GT)
JerZeyStangz
Northern NJ
Anyone have any idea where the oil pick up tube is mounted in the pan? Does it run along the middle or off to side of the crankshaft? I dented my pan in August and I want to replace it. I'm afraid I crushed the pick up because I am not sure if the tube runs along the side of the crank or directly under it. Secondly can someone post up a diagram? Thirdly, does anyone have any idea other than ebay on where can I get a used replacement for both items.
-Nathan
JerZeyStangz
JerZeyStangz
Northern NJ
I found this diagram but it doesn't show the placement of the oil pick up tube, because I dented it where the thin side of the pan is.
BLCKSTNG96
Runs down the side then turns and a short spot to the middle where the actual pick up is and uses a main cap bolt to hold it there,u can see it in that diagram.
