chl2isjodway
- Joined
- Aug 27, 2009
- Messages
- 6
- Reaction score
- 0
Hello there guys, I'm new to the forums and really could use some help, I'm not to skilled w automotive and don't have reasources for searching, here's my issue, I started my car up yesterday it was the first cold day since I baught the car and it was running ruff (heavy viberations from motor) I thought maybe just cuz it was pretty cold (50ish outside) well it only got worse after letting it run, started to smell like eggs, my exaust is unbolted right about where the driveshaft starts , well after finding I did still have cats I will remove them unless someone tells my that's a big no-no , however this is where the bad comes in... I had my brother in law come over and he noticed water/coolent comming out my exaust... that's a bad head gasket correct? And the reason my motors causing my whole car to shake so bad... ? Well whole purpose for this thread is I really don't wanna rebuild or replace my motor with another 3.8 , it is a 5speed 1998 , is it possible to swap to a 302 carb, and motor I go will be a carb to save time money and headaches, but will a 302 bolt to my trans and everything? What will I need to replace/upgrade and any suggestions on the most cost effective solution? I reallly don't wanna stay v6 unless I'm going to be replacing over $1000 in parts , so what are my options ? Thanks a ton guys, I will be changing my rear end to a posi if I do get a v8 of corse but ideas here or what cars/trucks to look out for to snatch the motor/parts out of would also be helpful, ill try to mark this thread so I can find it again but if u could message me that would be great, thanks so much guys , I'm also on unemployment so cost options reallly matter right now to me
