Orbital Polisher
SRT Handz
Porter Cable is the best orbital you can get for someone starting out.
Even Pro use Porter Cables. Mine is still going strong after 8 years of hard use!!!
G
GREG@SN95
Guest
Everyone says that PC makes the best DA buffer... (Dual Action or Orbital)
People that detail for a living use rotary buffers... They do the job faster and yeild better results. However, in the hands of someone with little to no experience or instruction are very dangerous as they can quickly burn through clearcoat or further is used incorrectly...
Personally, I hate DAs.. Work takes to long... lol And I have taught a few people how to operate a rotary buffer... its really easy you just need to know the do's and don'ts... Nice thing about a DA is its nearly impossible to fukc anything up...
G
GREG@SN95
Guest
CanaryGT said:
Why does a Rotary Buffer work better?
To remove defects you need friction and a little heat to remove small ammounts of paint or clear... A DA spins on 2 axises and what happens when you apply pressure (for heat and friction) it will slow down and stop rotatings (it kinda spins slow and makes little circles as if you were rubbing the paint with the pad by hand). Where with a rotary, when you apply pressure it will continue to spin as if there were no pressure. But if you apply too much pressure and/or keep the buffer in the same spot you will have too much friction and heat and kill the pant...
When you compound or polish a car what you are doing is removing a very fine layer of paint to remove very fine scratches and defects, not much different then sanding really. This is where friction and heat come into play, but if you have too little, its gonna take all day or not happen at all... and if you have too much, you will remove too much paint and totally ruin the finish...
This is why its very important that you know how to properly operate a rotary buffer. It is very easy to make a mistake... While with a DA, you can be a retard and not destroy your paint as it is very difficult for one to create enough heat and friction to chew through your clear/paint
CanaryGT
CanaryGT
Phoenix
Which one do you suggest I go with? Is one better to get swirls (spider webs) out easier?
i like my meguiars orbital buffer but read the instructions a da polisher will not get rid of spidering anyway you need a proffesional to buff the shit out of it
G
GREG@SN95
Guest
If this is you first buffer then stay away from rotary and go with the PC that handz recommended... If you are looking to upgrade buffers, then tell me what kind of buffer you currently have and how much you have used it
F
FullThrottleStangs
Guest
the PC is definitely what im getting, its just a matter of ordering it now :/ the mach needs a detail badly...
SRT Handz
Porter Cables are Legit. You can use it one handed and there is no way it can do any damage.
Rotary on the other hand handles business..... But takes ALOT of concentration because F*ck-ups can happen fast and easy.
F
FullThrottleStangs
Guest
mygreengt said:
it sounds like it needs more than a detail....
ive got my fingers crossed for it being the restrictor causing problems......
CanaryGT
CanaryGT
Phoenix
I hope so too man.
Hey Handz, If I keep buying all this stuff from CG, and I tell them you send me, do you get a coupon or something?
