overheating
drewski92
North Las Vegas
So my 95 is overheating really bad, i took out the thermostat thinking it was going to help it but it still overheats. I just replaced water pump a few months back but who knows.. Any ideas??
96TANGERINEGT
How hot does it get ? Take the coolant tank cap off and smell ( I know this sounds funny ) but if. t smells like exhaust , u may have a head / gasket problem
drewski92
North Las Vegas
it goes all the way red and sometimes past it.. as soon as it hits the white line i pull over, by the time i stop to turn it off its at red or further.
MustangChris
Aurora, CO
put the front of your car on jack stands (or ramps) open the overflow tank and let the car idle.
squeeze the radiator rubber hoses to help force the air in the system out to the overflow tank.
Anyone else have some suggestions on burping the system on a 5.0?
96TANGERINEGT
If it gets that hot something is deff wrong . Do a test on it to see if compretion is leaking into the coolant .
96TANGERINEGT
Oh , just found it napa has them , part # 7001006 . It's called a block test kit . If the the burping thing don't help ya
GT Rob
Houston Texass
Is the fan working. What happens when you trunk the key dose the fan come on also trunk th a/c on high and see if the fan comes on.mine did the same thing I changed radiator waterpump and it ended being the fan. Good luck with getting it fixed
CC'S95GT
Hampton ,Ga.
put the thermostat back in too.
without the thermostat, the water doesn't stay in the radiator long enough to extract any heat from the coolant. I'm running a 180* in mine but a 190* is stock.
toyman
Long before I would assume a bad headgasket I would look to the rad itself. Is the front obstructed with bugs, leaves or other stuff. Has the coolant ever been flushed? Water flowing too fast and not cooling is just BS. One could use the same argument that if it's flowing so fast it wouldn't heat up either. Total nonsense.
ram360
Does it overheat crusing on the highway or just in stop and go. Could be your fan not moving enough air and needs replacing.
LOL. Rethink this statement, it is absolutely not BS. A radiator, or heating/cooling coil's ability to gain heat (or loose it), all depends on the velocity of the coolant. Read up on hydronics, system balancing to be specific. A thermostat makes that flow restriction.
But to get back on topic, I've never run a t'stat in my SVO and I have never had that car even go 1/2 on the temp scale. I think the key is how long do you go before it overheats? Does it still overheat in cooler weather or when it's raining? The fan should really only be on when you're at low speeds, once you start moving, the fan does not do much. This all said assuming you are not loosing coolant and have to add some every day or have a bad radiator cap that drains your radiator when the system gets hot and is under pressure. With that said and HG/burping issues aside, the radiator is probably clogged with 20 years of crap.
I got an email with this yesterday...
http://www.americanmuscle.com/mishimoto-mustang-radiator-9495.html
Great price. I bet CJPP would price match it if you asked.
rz5.0
Great state of TEXAS
/\ I ran with out a t stay. It sucked car would get hot still.. Heater would not work if the car was just sitting at idle cold weather..put the stay back in fix it..
