pcv valve
95CALI-5.0
Same location as the fox 5.0's. Its in the very back center of the lower intake. You will see a hose running to it.
Hard to see. Just feel around for it. Can't miss it.
JarrettsGT
Insert dumb question here--------- Does changing the PCV valve make a difference? :uglystupid2:
WUZa5oh
If the valve is bad, it will make a difference. While you're back there, change the small filter too. When you pull the hose with the pcv valve on it, reach in the hole, the tiny filter is in there.
I think I heard it here : The only dumb questions are the ones that don't get asked.
AaRoN
King Post Whore
It's also better to ask a dumb question than make a dumb mistake. :thumb:
Paul
You don't really need to replace the little filter - just spray the crap out of it with some brake cleaner and you'll be fine. :)
Paul.
WUZa5oh
Paul.
That'll get the job done too. They're only a couple dollars new, so either way.
topless95
Paul.
Well I would take the filter out first :rollinglaugh: :rollinglaugh: :rollinglaugh:
JK paul
Paul
JK paul
Good point - I guess I should've mentioned that eh? :)
95gtdrop
sacramento
JarrettsGT said:
WTF 95gtdrop? :rant2:
my bad man. when i read it the first time, i thought you were making fun of me. then i read it again and got what you were saying. sorry man. :happydrunks: :banana:
94Pro-5.0
Little Elm, TX
lol
i just did the same thing. i replaced the pcv valve, cleaned the filter w/ carb cleaner, and replaced the rubber grommet the pcv valve goes into. had to lower itake off so i said what the hell
