pi cam VS stage 1 cam info
svtboy
I have read alot lately that guys are putting pi intakes and cams on npi engines with npi heads. I understand this is good for cars running superchargers that dont want the increase in CR. I also see people saying swap in stage 1 cams instead of pi cams. But after researching this I found that a pi cam has the same specs as a stage 1 npi cam. So you might aswell just put in a pi cam instaed of going stage 1 for $575.
http://www.crower.com/cat/domestic/ford/mustang_camshafts.shtml
ck5.0
According to that link the PI and the stage 1's look almost exactly the same.
jpajkos
I've heard a vt stage 1 cam in a p.i. motor and it didn't sound stock. Go on VT's site take a look at theres.
svtboy
Yes you heard it in a PI motor
Non pi cams are different, so if you leave the npi heads and swap the pi intakes the pi cams are the same as the non pi stage 1 cams
VT cams are for PI heads not non pi
540/550 lift, 224/226 .050" duration, 110 LSA
alexstang28
