PI swap with nitrous Octane?
96mod289
now that i am done with my PI swap I am planning on adding a 100 shot, but i have no idea how high of octane i will need  with the added compression and nitrous.  so dose anybody know what id the min. octane i will need to run ?
bigjohnson4.6gt
with nitrous you have to run higher octane, im pretty sure you would have to run 93octane
scarface
you have to run 93 with the PI swap. you should get a NO2 tune to be safe.
19mustang95
more like if you dont get a tune for the nitrous i will guarantee you will blow your motor...you also need new spark plugs with a 2 step colder heat range..
96mod289
i alll ready knew all of this info..... The question is with nitrous AND Pi swap what do i have to run for octane???
Pennywise2
Get a Nitrous Express plate kit with 100hp jets. :thumb:
You will need to run preimum 91+ octane when you plan
on spraying.Also you better get a good nitrous tune or plan on
buying a new engine.With 100hp jets you will need two step
colder spark plugs.If you are smart you should upgrade to a
larger fuel pump because nitrous is addicting and you will want
to up the shot sooner or later.A larger fuel pump is great insurance
that you will not run lean when you are spraying.
Good luck.
96mod289
well i asumed that because of the added compression requiring higher octane, and the nitrous requreing higher octane ,that i would need greater than 93 octane.
scarface
your thinking like its a carb car....its fuel injected. computer controlled. Run 93 octane, and get a NO2 tune. That way you get the most benefit, and don't blow up.
96mod289
for a tune, would a "mail in tune" from SCt work of should i just get it dynoed.
19mustang95
yes, but a dynotune will maximize the power...so i would go with a dynotune.
scarface
I personally would never use a "mail order" tune when yor engines life is at stake :(
Pennywise2
Yes, don't cheat your car get two dynotunes.
Get a N/A and nitrous tune.
96mod289
i fugured that the "order tunes werent that good but you never know.
chasingomas
