Professional Products
i_love_my_stang
has anyone used any Professional Products parts? just wondering how they are if their good or should i not bother using them, i was thinking of their intake manifolds
LAFENATU
The intakes are good IF you get them cleaned up. There is A LOT of casting flash with there manifolds.
The only thing I have bought was their balancer, and it was actually really, really nice for what I paid.
LAFENATU
i_love_my_stang said:
like the inside needs to be cleaned out, performance wise their ok?
Performance wise, it is basically a Edelbrock Performer manifold. They work just fine.
Like I said, there is a lot of flash so your gonna want a machine shop clean them up.
wcngt
I have one of their throttle bodies. Works great and I like the tps adjustment.
I run their TB too, one of the holes wasn't drilled in the right spot so i had to elongate it so it would bolt up. Then I realized the butterfly wasn't adjusted right and was sticking inside the TB housing so i had to adjust that. That being said I'm still glad I got it, I like it more than the BBK one I had and the TPS adjustment is very nice, plus hard to beat a polished TB for $140.
stang94X
get a set of fel-1250 intake gaskets and take it somewhere and get the intake gasket matched, that should clean up the mess of the intake, if the upper to lower ports are all jack up also, which it probably will be, get a gasket for the edelbrock performer intake and have the same thing done, performance wise, i dont know but it should be fine after the clean up
fastgtfairlane
i have the pp typhoon intake and its actually the edelbrock performer rpm not the rpmII. its a great bang for the buck part. sure the ports MAY need a lil clean up with a grinding stone but mine didnt need much. i got mine used on ebay for just over 200 bucks. i also have a pp 65mm throttle body and it fit and worked great. no problems whatsoever out of either of the two. oh i forgot to mention, the hole where the upper intake bolts to the lower the front bolt hole on the right needed some massaging to get the bolt in the hole. or you could run a stud in the right front and rear holes to solve that problem.
I
i_love_my_stang
man 200 bucks i wish i could get stuff in the states, i got quoted 700 bucks for them up here and the're the cheapest ones to get, i think the eldelbrock ones were 900 or 1000, trick flow online shipped were about 650,
Venom351R
Maine
Some of their stuff is good and other stuff is junk. I think they have a lower quality control standard then other companies so that's why their stuff is cheaper.
gt5094stang
also forgot to mension youl need the elbow adapter which is like $55 shipped to your door by pp also
I
i_love_my_stang
duty tax, i live in canada so i have to pay extra taxes just for shits and giggles on stuff ordered on any American site(which they all are)
