Project Cobra Jet
blizzND
West Fargo, ND
New to this forum but long time forum owner over at 351C.net. I'm a die hard canted valve 351 Cleveland guy so my car will be a bit different than most on this site.
I recently bought an already gutted out 94 Cobra, it seems that everything Cobra other than front bumper cover has long since been stripped and is long gone so I have no problems with the continuation of its metaporhasis into a strip/street car rather than the most often street strip car.
I have been lusting over the new Cobra Jet factory drag cars for the past few years, and when I found this R code '94 I thought what the hell, I'll start with the Cobra, add a 71 Cobra Jet 351C and a C4 and I'll go out and have some fun at the local drag strip.
As it turns out, after returning home from Kansas with the Cobra roller, I found a Marine in AZ that was stripping his Fox body drag car, with a 351C and toploader 4 speed, I needed a bunch of parts to finish mine radiator, fuel pump, headers, ect. so I basically bought everything radiator back to tailshaft, he is out in the 112 degree heat pulling it and will crate it and send it to ND for a cooler clime.
The roller came with a welded in 6 point cage, UPR adjustable spherical bearing rear suspension, 3 way adjustable rear shocks 8,8 with a 4:10 spool, Granitelli rear cover, C-clip eliminators Moser Axles and long studs for the Weld 15x10's and 28" MT drag radials. the front end has coil over drag stuts, UPR tubular lowers, and UPR crossmember, Weld skinnies and a fiberglass cowl hood of unnamed source.
I have already changed out the pedal set to a manual set, the power rack will be swapped out for a flaming river rack that will come from the Fox body car with the engine. I will have to do some tweeking to the steering shaft, I may just put in a FOx Steering column or replace it all with a pure drag race column and pop of steering wheel.
The interior was gutted but the car came with 2 dashes (neither with the Cobra Logos) a floor carpet a set and a half of interior panels two alum race buckets and belts that are date 2001 so they too go in the junk box.
the trunk spare tire well was cut out, and replaced with a piece of flat tin, with a 15 gallon fuel cell bolted to the tin, as well as a rear mounted battery.
the Body is in excellent shape, it is in primer and ready for paint, the car was in an accident in 1995 and was repaired very professionally, but I think the salvage title back then led her on the downward spiral that got it into racecar status. It has a replacement Mustang GT rear bumper cover, and the 94 lighted rear wing is missing.
I started gutting the dash of all wires not needed for the very basics of street legal, I'll leave the wipers, signallights and tail headlights. everything else will be stripped from the harness.
I'll post pictures later today.
-blizzardND
blizzND
blizzND
West Fargo, ND
Been a big week, the body shop has painted my doors, hood, trunk and bumper covers..
then I received word that my engine, transmission, radiator, fans, headers and everything else under the hood is, boxed up and shipped out yesterday.
blizzND
blizzND
West Fargo, ND
well my parts arrived in a very large crate..
once unloaded I had parts all over my floor, and we can't have that can we...?
so I used some old casters, some used drywall screws and fashioned me a temporary storage unit out of the crate
then filled it with my Cobra Jet Parts...
the one thing that I noticed is parts from AZ in a crate whos side had opened up get very dusty, here is the new engine, and some parts still covered in road dust.
This weekend I start welding up the chassis, I'll weld in the stock rear upper/control arm brackets and start up front with the engine compartment.
~blizz
uncltrvlnmatt
Pa.
Cool project good luck with it. Also nice shop, is that a painted floor or epoxy coating. Nice Bronco, What year?
Suspect
ATL
+1 cool project. liked how the box turned into shelves!!
Blakonblak94
What sort of numbers should the motor put down?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Wow very neat build. I'll definitely be popping my head in here once in a while.
Can't wait to see the progress.
Musturd
This is awesome , I was looking at 351 c fuel injected intakes a while back because I thought it would be a cool swap
blizzND
blizzND
West Fargo, ND
thanks guys, yes the floor is epoxy, ~9 yrs old and many projects, so its getting due a re-coat, this next time with sand in it, as expoy floors and snow get very slippery, water ok, but a skif of snow+ slick!
>The Bronco is my wifes '68 halfcab, 400FMX block in it with a ford toploader 3speed OD trans. Father in Law bought it new Dec '67 33,000 original miles, never left the western ND ranch till we brought i to Fargo 8 years ago and restored it. 30K ranch miles was very hard on the old Horse.
>Engine as is should be ~400hp, with the toploader and 4:10's I'm hoping to dip into the high 12's, just want to have fun, I'm not a competitive guy and I don't think I'd ever be consistent enough with a stick to go more than a round or 2 with some help from the other guys red lights and breakouts. I plan to just drive it as hard as it will go every round, and see if the other guy screws up. (quite the strategy eh?)
her's progress from the weekend...
I moved the previous owners rear brace forward 12" so I could drop the fuel cell down in to the trunk to make it easier to fill
and welded up all the suspension points, Be careful if you do this yourself, that factory tin when hydro-formed or stamped gets really really thin in spots, #1 setting on wire feed, lots of wire speed keep the stick out less than 1/4 inch..
I had a preformed trunk sheet metal bent up and got that trimmed to fit the floor cutout too. the Previous owner had the rear bars welded to the shock towers directly, I had to cut them out, install the plates and I'll put a 36" tube across once the floor is welded in. gotta think whats the easiest way and in which order.. :)
then took Sunday off to go to the local drags, the had the "Radial Revolution" guys out of the Twin Cities in town. 15 cars, 12 of them Mustangs, mostly Big Block chevy Mustangs :( But bad ass, 150mph plus in the 1/8 mile!!! they ran though Ice and Nitrous like someone was giving it away at the concession stand. I saw 6 empty bottles at one trailer and on guy told me he went though 112 lbs of ice, in 5 passes.
I took some idea pictures and then my phone died..
twin turbo SBC :( sweet well built car used 112# of ice in 5 passes..
Neighbor kid loves cars, passed up playing basketball with 2 young ladies to help me work on my Cobra Jet project. bending fuel cell brackets..
_blizz
blizzND
blizzND
West Fargo, ND
Drag Strips are a great place to get ideas, and catch the fever.. funny how few show car and street car guys actually attend drag races.
Support you local strip!
here is an Outlaw SN95 COBRA doing its dance and ready to strike... (from the 'net)
