Question about stock MAF.
5.Woahhh
How many MMs is the stock MAF?
How bad would it be if I ran it with a 70mm TB?
Downshift
I believe the stock Maf is 70mm. And yes you will be perfectly fine using a 70mm throttle body with it. I will say that if this is one of your first mods that gears and full exhaust or at least a mid pipe would put a bigger smile on your face. Meaning I would do that first, if you already have them then go for it.
5.Woahhh
Already have a UPR X and some Magnapacks on the way. I was just told that you should run a MAF bigger then the TB.
ScottyDsntKnow
Stock MAF is a 70mm although they have that gigantic bar in them that cannot be good for airflow. There is a big debate about the usefulness of running a bigger TB. Some claim that you lose low end with a 70mm and should go with a 65mm instead. I dunno, IMO the intake opening is 70mm so thats what I run.
LAFENATU
65-70mm is the best for a sb 302 that is N/A
Boost I would do a 70/75mm TB.
