*quick backspacing and offset question*
lrall
What is the spacing for 94-04 mustangs on the lugs? Is it 5 x 4.5", also does it change to the 05 years? I know the foxbody's are 4 lug. Im trying to find some rims for my s10/48 chevy project and i love the bullitt style rims
-lr
uncltrvlnmatt
Pa.
Re: quick lug spacing question
In the past Ford and GM wheels were not interchangable. You could swap Ford and Dodge wheels. I guess this post was really useless and did not help. :dunno:
Hybridbird
Yeah,the SN 95 bolt pattern is 5x 4.5 (or 5x114.3 for you metric minded types) and the new Mustangs are the same except with a much higher offset,like a front wheel drive. The bolt pattern for the S10 is 5 x 4.75 so it won't work for you,sorry.
L
lrall
oh on the flip-side mr hybridbird, they may work haha. I found some wheel adapters(we needed spacers anyway) Do you, or anyone else, know the backspacing and offset for factory mustang rims? for both sn95 and new edge if its different
L
lrall
anyone know? i see you can buy 17x8 bullitt rims but they show 4.75 backspacing and 0mm offset, thats not possible
Hybridbird
Thats entirely possible, 0 offset means that the mounting flange is exactly at the center of the wheel and that from that flange to the inside lip of the wheel is 4 3/4 inches.That wheel would however,be for a S197 Mustang.The SN95's and and the new edges (99-04) use the same bolt pattern/ offset.
L
lrall
that would mean that its a 9 1/2 inch wheel, found the answer on another forum, 5.72"(145mm) back spacing and +30mm offset
Steven
SC
offset on 94-04s.. are 24mm.. my 06 gt wheels i had, were about 30mm offset, they almost had them flat against the outer edge of the wheel. need like 1" spacers out back atleast and 1/4"+ in the front to make the work, but they fit :dunno:
L
lrall
what makes you say 24mm? everywhere ive looked and read now(3 forums) have said 30mm
Steven
SC
everybody has there own opinions.. guess it depends on the guy :dunno:
