Radiator Cap/expansion tank question
JerZeyStangz
Northern NJ
I have Lisle bleeding kit to burp excess air out the cooling system, but I am not to sure our cars have legit radiator style caps. The only cap that I know of is on the expansion tank. The question is that the kit is made to go on a radiator, what should I do?
19mustang95
Unless they make an adapter that is the same size as the cap on the expansion tank, you wasted your money buying that.
Blind
As an Amazon Associate we earn from qualifying purchases.
JerZeyStangz
JerZeyStangz
Northern NJ
Duff Daddy said:
you need to get a screw on adapter kit for it.
Can you show me the screw I need for it?
Blind said:
if you have this kit, it's the same one I have, and it works great on sn95 expansion tanks.
http://www.amazon.com/Lisle-24610-S..._1?ie=UTF8&s=automotive&qid=1307063372&sr=8-1
the adapter you need came with it, one of the yellow adapters fits tight in the expansion tank and nothing leaks, unfortunately there's no threaded cap to hold it down tight, but I've not had any problems using it.
I have the same exact kit, I'll definitely need to try it out because I want to burp the coolant system!
