radiator fan on start up?
Miltoid
Turning the heat on doesn't do anything for burping air out of the system, so forget about roasting yourself in summer time.
Thermostat has nothing to do with fan activation. The temp sensor detects hot water independently of thermostat operation. Thermostat only exists to allow cooled water from radiator to enter the engine block.
There is a strong possibility of trapped air within the system. If you saw the white smoke coming out of the tailpipes, your engine has a blown head gasket and may already be ruined and need of a rebuild. If the white smoke came from under the hood, there's a chance that boiling/overflowed coolant simply leaked onto something hot like an exhaust manifold.
Chasing any remaining air out of the coolant system should be the current focus. Taking the car to a shop with a professional OBD Sanner to run a test of the coolant fan should also be a high priority.
The first that came to mind for me was also the head-gasket, If you rev it up cold and see bubbling and turbulence in the coolant you may have a problem.
SnakeBit!
Florida
I did not read through this entire thread, however, in case not mentioned, fan doesn't come on with the ignition unless the a/c is on. otherwise, the fan comes on once the car gets to operating temp and the temp set in the ECU if changed from stock.
C
chasingomas
San Francisco, California
understandble lol! wasn't turning on with a/c. replaced ccrm and replacinggg coolant temp sensor cause I was being a detective. Thanks for saying it plainly too :)
C
chasingomas
hey y'all; fan still wont turn on. I've replaced the coolant temp sensor, the ccrm, thermostat, hoses. Relay was checked and good. when electricity went through the fan from the battery directly, it spun. What am I missing y'all? feeling super dejected but determined i guess
C
chasingomas
the pigtail connector to the sensor seems a bit damaged and I got a new one to replace it; could this be causing the issue? Weird that it still isn't turning on for a/c I'd assume
it seriously takes less time to pull and inspect each fuse than it does to look through the book and then we can be sure they are all good. Some circuits feed multiple things.
C
chasingomas
will do. replacing the 40 amp fuse with a 50 amp from o'riellys should be ok? The manual says it should be a 50 but a 40's in the car
Farmer83
